Road_Runners
May 12, 2013Explorer
I know you have probably done this, but have you jacked up a wheel spun it and then engaged the brake controller to actually see that the wheel stops spinning?
When I replaced my brakes I put on four new complete brake plate assemblies. After that I found that one of the wheel brakes was not working. I looked at everything I had done and everthing seemed to be in order, but there was no voltage at that wheels magnet when I applied the brakes.
I use a good RV man that comes to your house. I called him and found that even though I thought I had completely stripped a wire at the brake before putting a compression fitting on my RV man showed me that there was still a clear plastic coating over the wire. He stripped that plastic coating off and reconnected the wire and everything worked fine.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
