DutchmenSport's avatar
Oct 06, 2018
New camper, water heater problems already - but fixed it.
Took delivery of the brand new 5er and set it up at home. For 3 days everything worked OK. Then headed out for the first week-end trip and the gas on the water heater would not fire. I tried the simple stuff first, like switching over to the other propane tank, and it did work ok again.
Took off again this week-end and found out the gas won't fire on again. I could hear the click-click-click of the spark attempting to light. It would do it twice and then stop attempting.
Sometimes, there would be an explosion of gas, and it still would not light.
So, I finally got desperate Friday morning and called my dealer service "again" and gave me a suggestion. When I stood there, really looking at what he was saying, I told him I'd try his ideas and see what happens. If that didn't get it running, I'd be bringing the camper over on Monday for them to look at. Thanked him and got off the phone.
I turned the gas button off on the heater so it wouldn't try to spark on me and the first thing I did was remove the spark probe and bent the 2 wires so they are now more in front of the orifice outlet.
Because I didn't want to tear the whole thing apart, I took a large zip tie, tied a small shop towel wad on the end and pushed it through the burner orifice. Well, happened next was truly the "AH HA" moment!
When I pulled the wad back out, a dead stink bug came out with it. At home, we are being infested with those darn grey stink bugs that look like small flying short and fat ****-roaches. They are in everything. I never thought about one crawling inside the water heater parts.
Well, with the dead bug gone, I put everything back together, flipped the gas switch, and it fired up immediately!
The dealer service guy said I could have a spider web in the orifice. No spider web, just a dead bug.
Who would have thought such a small thing like that could cause such a big problem.
With my previous travel trailers we never had bugs or spiders attack the water heater, in years and years of ownership. Even last year, which was a horrible year for stink-bugs, none ever got into the water heater or furnace. I suppose a lot of "firsts" are happening with new camper ownership this time. I'll definitely be getting one of those screen covers for the water cover now.
Meanwhile .... water heater is now working great on both gas and electric, at least until I get back home and face the stink bugs again!
  • Had to bomb our camper for stink bugs. I even found them in the folds of the generator air filter.
  • The screen might help, but the stink bugs can flatten themselves and get in the crack around the cover. I was in an infested campground some years ago and when I popped off the cover there was a complete line of bugs around it.
    It is my understanding that stink bugs leave a trace odor to find their way back to their hiding place for the winter. It might help to wash the affected area as best you can.
  • Glad you got it cleared up.
    Propane system is only 0.4 psi (11"WC) so it doesn't take very much to disrupt the flow
    With the low pressure the air/fuel ratio is critical and anything that disturbs that ratio will prevent ignition
    Just for some clarification
    Burner ORIFICE...that is the gas nozzle. It is very small metered opening
    Clean by soaking in alcohol and then blow dry using LOW Pressure air...never poke anything thru the small opening as that will damage it
    Burner TUBE.....pipe that air/fuel mixture flows thru to combustion chamber opening where the Spark Electrode ignites the flame. Propane must flow down center of tube, drawing air in and then mixing. IF tube is not aligned the propane will bounce off sidewalls of burner tube and NOT mix with the air causing ignition issues due to incorrect air/fuel ratio
    That is why a spider web can cause issues.
    Spark Electrode needs to be 'engulfed' in flame when it ignites...flame proving
    And spark gap (distance between electrode/ground rod) should be 1/8", high tension wire connection clean/tight and ceramic insulator not cracked
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
