wanderingaimles's avatar
May 06, 2019
New coffee maker
Weve been using an old style percolator on the stove top for years in the camper. I was afraid my drip unit would be too hard on the batteries. But I've slowed down my former 2 pot habit to what the pot says is about 6 cups a morning. My old drip unit used 120 VAC at 1100 watts when brewing and stayed high on the power draw for much of the 2 hours it was on before auto shutoff. I just bought a little Mr Coffee 5 cup unit and have tried it for this mornings coffee with the kill-O-watt meter on.
Brewing a 5 cup pot, and then running the warmer for the one hour period the timer gives it used .1 kwhr. So apparently I should be able to use this off an inverter in the camper for only about 1.1 Amp hr off the batteries.
The max draw when brewing is about 660 watts, and after about a 4 minute brewing cycle it cuts out and starts cycling about 5 minutes off and 5 seconds on for an hour.
It will be great to not run the stove every morning in the summer adding more heat to the camper.
  • I'm partial to the old Mellita pour through coffee maker. Boil water, pour it through a cone filter filled with coffee, done. Coffee never last long enough camping to get cold anyway.
  • RoyB's avatar
    RoyB
    Explorer II
    We use the CUISINART Grind and Brew Coffee maker. It is only 'ON' for about five minutes then switches completely off. The hot coffee is stored in a thermos carafe... This stays hot for many hours...
    This is great for me when I am off-grid which is 90% of my camping...
    This is the one I use... I of course have the ole Coleman stove top perc for backup... I also carry a MR COFFEE portable coffee grinder that will run off my 2KW generator or truck when needed...
    google image
    I also bring along my favorite taste bottled water just for the coffee maker. This insures I get the same coffee taste wherever we go...
    Roy Ken
  • We use a basic 12-cup Mr Coffee drip unit (just has an "On/Off" switch) that draws about the same power when brewing. When it finishes, we just pour the coffee into a Thermos "AirPot" insulated carafe that we draw from as needed during the day. If the coffee cools down too much before we get to it, a 30 second blip in the microwave heats a cup up again with no "old" taste.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
