2001400ex's avatar
2001400ex
New fifth wheel. Questions
So I just picked up my fifth wheel today and drove it way too many miles home. Yesterday they installed a B&W turnaround ball, Firestone airbags, and the Anderson ultimate hitch. The fifth wheel is a stealth 2816 (32 foot). So I was agitated because yesterday they didn't install the chains or the plug in the bed. So I had to stay the night in hotel (I brought extra clothes, thankfully). This morning, they do the plug but say that since I don't have the puck system, the B&W turnaround ball they installed doesn't have anything to anchor to. I look it up online and the ones I'm looking at all have 2 u bolts, I tell him they installed the wrong one.
Anyway, we get over that and I come outside and my pickup is already hooked up. The trailer looks a little nose high, but it wasn't on level ground so I figured they did it right. I stop at a rest area a while later and get to looking at it. Like WTF?
So I'm driving along, talk to my brother. I decide to check the air bags when I get to the next gas station. I look at them and see this on the left side. Again, WTF?
I'm surprised it didn't pop given how much it was digging into the side. So I check the pressure, one was 75, other was 70. Reduced them both to 50 and it was more level. Tomorrow I am going to take it to a local shop to see if they can fix the bags. I also was looking at how they installed the red part on the pin box, here it is.
Here are my questions.
1) Did they install the wrong B&W turnaround ball? (Please no discussion on chain requirements, I have read about 20 of those threads) I have the chains just no where to hook them to.
2) Is the part attached to the pin box backwards or it is the right direction? It looks like it would move the trailer 4 or 5 inches further back if turned around. I backed into the driveway and got to about 45 degree angle and it didn't hit the cab. But I wonder if I have enough clearance for everything I need to do.
3) The tires are 235/80/16 10 ply load range E and are marked for 80 PSI. I had him check before we left and they all were at the 60 PSI. He said that's where it should be. I'm like, man shouldn't they be closer to 80 or at 80? He says no, he worked at a tire shop for 13 years, if you put them at 80, they will blow. What do you run your tires at for cold PSI?
4) Even dropping the pressure in the air bags, it was still above level. I was going to drop the ball one hole on the Anderson hitch. I have plenty of clearance, do you think that is the right adjustment to make? And I need about 6 inches of clearance, right?
Please let me know your thoughts.
BTW.....I was surprised that my fuel mileage was similar to that of the Shockwave 21 bumper pull in my signature. That one was 5,224 dry, this one is 9,800 dry. I track every tank in an app and hand calculate, so I checked to the same trip I made last year (although last year I was mostly fully loaded and this trip I was plum empty).
  • My truck door sticker says 80 psi so I run 80 psi. I suppose if I wasn't towing I could lower the pressure?
    I can imagine that the air bag is going to have a hole eaten in it.
    I dont know how your hitch compares to what I found while searching but this pic shows the cable on the left.
    This video also seems to show the cable to the left which puts the ball to the front.
    This video shows it either way?
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
