dodge guy wrote:
But that’s my point. If I have to turn off systems that are needed like the charger, then the generator is too small.
well, using that logic a 30A service is to small. I can't charge fully depleted batteries, run the AC, the WH, and the microwave at the same time..... darn. guess I need to go to a 50A service.
Seriously, except at higher altitudes where one honda 2000 can't necessarily run the AC, I've never been in a situation where I felt the honda 2000 wasn't doing an adequate job of supplying my generator needs including running the AC especially in conjunction with the micro-air easy start.
and in most cases, I CAN run the converter AND the AC with my honda 2000. as long as the altitude is below about 3500 ft and my batteries have 80 percent charge or more I CAN run both. and that cover 99 percent of my needs.
