SteveAE's avatar
SteveAE
New porch light
Hi,
I am tired of the single bulb, low light output, of the porch light that came with my trailer. Put a LED in there a number of years ago, but it's still not bright enough.....or, more likely, my eyes simply need more light than they used to. Seldom have it on, but when on, I want to see. Bothering anyone with "light pollution" isn't an issue where I usually am.
My buddies new trailer has lots of light, but I would rather not buy a new trailer just to get more light.
Any suggestions for a different fixture I can put out there?
Thanks,
  • Durb wrote:
    I have two of these as scare lights on the front of my trailer. They are really bright, in my mind, too bright for a porch light. If you want, PM me an email address and I will forward a photo that illustrates their intensity.
    Could you reduce the supply voltage to make them dimmer, whenever full brightness wasn't needed?
    A lot of LED fixtures are regulated (so that they produce the same brightness over a wide range of supply voltages) - but after you get below that minimum regulated voltage, they can still be dimmed.
  • IAMICHABOD wrote:
    This one,not cheap but BRIGHT
    Porch Light
  • I agree, good folks. I got all my LED bulbs from them. Didn't consider them for fixtures, but I will take a look.
  • IAMICHABOD,
    I like it. Thanks. Will see if any one else has any other suggestions b4 I order it.
    Rescue,
    Where we usually go there isn't anyone to bother. But, if I needed light to see so I didn't fall down and injure myself then.....who cares.
  • jdc1
    I guess you didn't see where he said LIGHT POLLUTION IS NOT a problem where I normaly go!!!
  • I rarely use my porch light. When I need more light than the night provides I strap on a headlamp which doesn’t bother my neighbors. How do you know lots of lights don’t bother other campers? Wishful thinking?
  • jdc1's avatar
    jdc1
    Explorer II
    They are low light emitting for a reason. While out camping, who wants the guy next to you shining his light on you and your peaceful campout?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 24, 2026
