TMX's avatar
TMX
New Poster - New Tower - Pre TT buyer
Good morning and first off thank you in advance.
I looked but did not see an introduction Forum, if there is one please point me there :B
We are about to rent a TT for a trip from Colorado Springs to Yellowstone. We have great resources for low price rentals through the various Military Bases here in the Springs. We are using this as a way to test out different TT before we buy at the end of the season.
My main question is on how heavy of a TT can I tow?
I have a 2014 Chevy Equinox with a tow rating of 3500#, it is the AWD V6, LT2 with Tow Package. It has either a Class I or II hitch mount with the 1 1/4" receiver
We are looking at 2 different trailers:
RPod 171 :
Hitch weight 225#
Base Weight 2205#
RPod Link
Scamp 13'
Hitch Weight 100#
Base Weight 1200-1500#
Scamp Link
The owners manual says that the towing cap is only 1000# if the trailer does not have breaks, and neither of these do.
For the record, there is only a $50 difference in the weekly rental price between the 2, and the RPod is MUCH nicer...lol
Are either of theses doable?
Thanks for the time you took to read this, and for any and all help I get.
Tim
  • Before looking into a pop up tent trailer check where you will be camping. Some of the National Parks with bears do not allow tents or soft sided campers in certain areas. They have areas you can camp but make sure you can get a site in one of those areas.
  • I agree with Burbman, except for this line: "...You get more room for the money...". Have you looked at the price of pop-ups, lately? :h
    The vehicle you are attempting to tow with does not allow for much of a trailer. You may be better off towing a 6x8 utility trailer loaded with a huge tent and camping gear. If you insist on a trailer, then a very light weight, small (probably no bigger than an 8' box) pop-up would be your best bet. After you up-grade that receiver....manufactures put those receivers on there to haul bicycles and not much more.
  • The R-Pod has electric brakes, they are an option on the Scamp models. I wouldn't tow anything without brakes on it, the laws in many (not all) states requires brakes on anything over 1000 lbs.
    That said, you will need to upgrade that 1-1/4" receiver on the Equinox to a 2" receiver and also have trailer wiring and a brake controller installed. If you look at the tow ratings in your owners manual, there is likely a restriction on "frontal area" of the trailer. The reason for this is that high profile trailers like RVs create a LOT of wind resistance which adds more drag to the tow vehicle (TV) than the actual weight of the travel trailer (TT).
    Also remember that you will pack a few hundred pounds of stuff in the trailer, so the real weights for the R-Pod are closer to 2500 and about 2000 for the Scamp. Also pay attention to the cargo capacity of the Equinox, look at the yellow sticker on the driver's door jamb. The 250 lbs or so of hitch weight on the R-Pod will be part of the cargo that the Equinox will carry.
    I would say that would be likely be OK with the R-Pod IF you don't load a bunch of stuff in the back of the Equinox also. BUT, that's about as big of a TT I would tow with that vehicle. The Scamp would be a better match weightwise, but having looked at both of the links you provided, I get what you mean about the R-Pod being a LOT nicer.
    Have you looked at pop-up trailers? You get more room for the money and because they are low-profile when packed up they are a LOT easier to tow than a hard-sided trailer. Our first trailer was a pop-up when we had our 97 4Runner with the V6 in it...we didn't go with a full sized TT until the lease was up and we got our Expedition.
    Smart move renting first...maybe you rent the R-Pod for a weekend and take it someplace closeby, then you can see how the Equinox tows it before you commit to a road trip. If it turns out to be too much trailer for the vehicle, at least you won't have gone too far with it.
  • NO, they both weigh well over 1,000 lbs. so need brakes. find a light one that does have brakes
    bumpy
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
