Brownleaf's avatar
Brownleaf
New propane tank
Due to severe rust i will be needing a new propane tank. From where would i get one and what is a typical cost to remove and install? Doug
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well based on the OP's post I am assuming that it is a ASME Tank permanently mounted in a motor home. I would check with an RV dealership AND a Propane Distributor
  • A propane "TANK" is typically mounted permanently onto the RV. If you can easily remove yours by releasing a clamp, it is a propane "CYLINDER". The two are totally different and are treated differently.
    Which do you have?
  • Is it a Dot or portable tank, or an ASME permanently mounted tank?
  • So what size tank are you looking for, as there are many types and sizes.
    As for the rust can you not sand or wire brush it off and repaint?
    Check this site out may help; https://www.rvpartscountry.com/RV-Propane-Tanks_c_387-2-1.html
  • The cheeky answer might be.....you can get a one litre green bottle for a camp stove or a 1000 gal tank for commercial use. What do you need? But of course being a Canadian, I would never say that to you.....
    Assuming you need something for your RV, you could check with your local Costco for sizes and prices. For onboard tanks......? Local RV dealer maybe.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
