Abbadox's avatar
Abbadox
New Tires For A Brand New Trailer
So as someone that has yet to own a travel trailer I have been watching YouTube and a couple of the videos are recomending getting new tires or upgraded tires when you buy a new or used RV. I plan to buy a new Della Terra. How do I know if the tires that are standard on it are good enough or if they need to be upgraded.
  • New....run for a couple of seasons
    Used.....check the mfg date on sidewall if tires ---4 digit number week/year
    Usually on sidewall that is on inside of trailer so you will have to crawl underneath to see it
    If older then 4 yrs ....NEW tires
  • If the tires are fresh I would give them a season or two before you replace.
    Otherwise post up the exact tire and size when you bring the trailer home.
    I recommend getting tires that cover the full GVWR of the trailer.
  • They are “good enough” if they haven’t aged out, if you don’t overload the TT, if you keep the air pressure at the sidewall stated max pressure, if you don’t exceed the max rated speed, and if you cover them when not towing. My TT came with load range C tires. When they aged out I moved to LR Ds.
