- harley001Explorerthanks i will get it on the right forum my truck is a dodge ram 2500 diesel and would be a 2009 furzion 302 f//w not sure about the gvrw i think around 8800# the truck is rated to tow 14,300
mike - BarneySExplorer IIIAccording to the question he asked, this is the correct forum for it. If he doesn't get enough good replies then I will move it to the Toy Hauler forum but I suspect he will get his question answered completey here. This is the type of question this forum was designed to cover.
Mike, Welcome to the forums! I hope you get all your questions answered completely and come back and post often.:)
Barney - MFLNomad IIWelcome to the forum Mike!
You aren't giving much info on the truck or trailer. It would likely take a diesel powered Ram, to pull that size trailer. Depending on hitch weight, gvwr of the trailer etc., the 3/4 ton may not be able to carry the weight.
Jerry - donn0128Explorer IIWelcome to the forum.
First rule, be sure what forum you are posting in. There are many different forums here and many newbies tend to start posting before checking out the different forums.
As with your post, it would probably be better read by posting over on the Toy hauler forums. I will ask the moderator to move it for you.
What is the TH's GVWR and is this a pull behind or a fifth wheel.
It will make a difference. Regardless, dry weight numbers are totally meaningless. No one will ever tow a "dry" trailer. Once it is loaded with stuff it will be far closer to the trailers GVWR. So you really need to base everything from that.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
