willald's avatar
willald
Explorer II
Jan 27, 2022
new towed vehicle - Jeep Wrangler
Well, for various reasons, we have decided to pull the trigger, and trade one of our older vehicles for a Jeep Wrangler. Wife and I both have always loved Jeeps, wanted to one day own one, and now we going to make that happen. :)
Part of what motivated this as well was the fact that we live way out in the country where it is very hilly, and are finding that when it snows here, they do not plow or salt any of the roads. Hilly roads, unplowed and unsalted when it snows means, without a 4x4, you aren't getting out when it snows or roads get bad.
We went with this silver 2018 Unlimited Sport model (JK). I wanted one that was built on a ladder frame (not unibody), so that was why we didn't look for anything newer than 2018, and wanted a JK model.
We already have the Ford Taurus we tow behind the RV (4 down), and it is working fine. However, I definitely am planning on setting the new Jeep up to flat tow as well, as there are places we go where we'll want the Jeep instead of the Taurus.
At any rate, that brings us to what I wanted to talk about here: Setting up a Jeep Wrangler for flat towing. We use the Readybrute/Readybrake on the Taurus, so will be setting up the Jeep with the Readybrake and Readystop cables. I will probably get a Cooltech wiring harness and wire in the Jeep tailights for flat towing. Any hints, suggestions on installing the wiring harness and readybrake cable, would be welcome. :)
What I'm mostly struggling with right now has to do with the base plate set up in the front. I see a couple options:
1. Replace front bumper with one that allows you to bolt the Blue Ox brackets directly to the front, like the Rock Hard 4x4 Patriot or Rugged Ridge Spartan bumper. Really like this idea, but problem is, unless you spend a ton of $$ on an aluminum bumper, you are looking at a steel bumper that is very, very heavy. Don't want to make this jeep any heavier than it already is if I can avoid it. Are there any bumper options out there, that you can connect blue ox brackets to, aren't so heavy, and not so hard on the wallet?
2. Blue Ox base plate, installed right under the bumper - Really leaning this direction, but hate that it sits so low under the bumper, and vulnerable to a rock or something hitting it, as we do plan to do some off-roading now and then.
3. Currie Rock Jock tow bar mounting kit - This one replaces front air dam/chin under the bumper with a steel piece that has tow hooks incorporated into it, that tow bar would attach to. Like this one, too, and its definitely the least expensive, but questioning how strong it'd be, given the way it attaches. Its just bolted on top to the stock bumper, and on bottom to frame cross member. Doesn't bolt directly to frame rails like other ones do, so not sure if it'd be as solid. That, and the position of the tow hooks has me concerned it'd make the tow bar clevises rub up against bottom of the (stock) bumper.
Soooo, Jeep owners that flat tow: What recommendations do you have, as far as how to set it up for towing? Anything else I need to know? We pick up the Jeep Saturday (can't wait!), would like to have it ready to flat tow by April for upcoming trip to the beach, so need to start ordering stuff fairly soon.
  • For me, the hardest part about installing the Ready Brute cables was getting up the courage to poke the holes in the firewall in a brand new vehicle. Once I got that under control it was a simple task to install the cables.
    Well, this one isn't new, technically, its 4 years old. And, there is considerably more room down there on the firewall than there was on the last two vehicles I installed the Readybrake cable. Sooo, I'm not worried about that part. :)
    Similarly with the wiring: I liked the CoolTech harness, but didn't like the price so I sourced my own wire and switch and built my own version. I put the switch in the dash rather than under the passenger seat so it's more convenient to reach from the driver's seat, but it required routing the wire up behind the dash. I think I spent less than $30 for everything for that harness.
    Yeah, I'm seeing that the Cooltech harness is pretty expensive. I'm now debating between a Hopkins custom kit that plugs directly into factory wiring harnesses at each tail light (cost about $84), or maybe a separate bulb kit, as it seems the Jeep taillight assembly has plenty of room to put in separate tail lights. Not sure yet.
    On my Gladiator I went with the Rugged Ridge Spartan bumper. It won't add too much weight up front because it's replacing the OEM bumper, not adding to it. I don't recall the actual weight of the bumper, but it wasn't much more than the OEM one - I had no problem installing it by myself.
    Hmmm.....I read some bad reviews on that one, saying that when they bolted the blue ox brackets on, it deformed the bumper and cause the powder coat to flake off. That was other reason I was a bit afraid of that one. Have you not had any issues with that? That, and I read where the company that made it openly admitted their bumper was not designed to do such.
    On my wife's old Wrangler (2107 JKU) we used the Blue Ox base plate - it did hang down from the front and while we never had it impact the ground the thought was always there because it DOES reduce your approach angle a bit.
    Indeed so, although I'm leaning more and more that direction, as I don't see us doing any really hard core offroading where approach angle would be a factor. Other good thing about the Blue Ox base plate, is there is already a place right there on it for the 6 way wiring connector and the readybrake cable. Otherwise, would have to figure out another place to put those.
    ...on my wife's new 2022 Wrangler we're going with the Maximus 3 Tow loops - they hang below the bumper, but not as far as the Blue Ox base plate. She decided she didn't want to change out the bumper...
    Hadn't seen those, but looking at it, not sure how you'd attach Blue ox style Clevis attachments to it?
  • jdc1 wrote:
    I doubt the Blue Ox base plate will be any lower than the differential is right now.
    Well, no, but it's not ground clearance so much as it's the approach angle that is a concern.
    The newer JL and JT models still use the same ladder frame. I don't think that will EVER change so long as the Wranglers are in production.
    For me, the hardest part about installing the Ready Brute cables was getting up the courage to poke the holes in the firewall in a brand new vehicle. Once I got that under control it was a simple task to install the cables. Similarly with the wiring: I liked the CoolTech harness, but didn't like the price so I sourced my own wire and switch and built my own version. I put the switch in the dash rather than under the passenger seat so it's more convenient to reach from the driver's seat, but it required routing the wire up behind the dash. I think I spent less than $30 for everything for that harness.
    I don't have any knowledge of the Currie system, but on my wife's new 2022 Wrangler we're going with the Maximus 3 Tow loops - they hang below the bumper, but not as far as the Blue Ox base plate. She decided she didn't want to change out the bumper...
  • jdc1's avatar
    jdc1
    Explorer II
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 26, 2025
