ggates's avatar
ggates
New Trailer and Truck
I currently pull a TT (<10k) with a 08 Ford Superduty (SRW). We are looking at switching to a new trailer (5ver) and likely a new truck. We are considering a Grand Design (Solitude 344gk). It maxes at around 16k lbs. We really love the new 2020 GMCs. I also intend to put a fuel tank in the bed (1000 lbs) and a heavy hitch (Hensley).
My dilemma is SRW vs DRW. I really prefer a SRW (size, parking, etc.), but don't want to make a mistake and have to replace the truck in 2 years. I live in NM, so altitude and mountains are a real effect, but we want to use it to travel the country as I retire.
Any real world advice/experience would be appreciated. Thanks in advance.
  • Absolutely no debate with that weight of a trailer, duals. You may even be approaching the 450 arena.
  • ggates wrote:
    I guess the question was as much about hitch weight as capacity (since I would be new to 5ver).
    Math follows:
    If I assume 10-15% tongue weight of 16K = 1600-2400 lbs. With fuel (1000 lb), plus hitch and DW (500 lb), that would put me just under 4000 lbs (payload of a SRW - 4078 lbs).
    But I have seen people indicate 20-25% tongue weight (3200-4000). That again puts me at 4000+1000+500 = 5500. About the payload of a DRW (5607 lbs).
    So depending on what the actual hitch weight is, I could be up against the weight limit for either SRW or DRW.
    Bigger is "always" better. I just was wondering if anyone made a SRW work.
    Let me start over, welcome to the forum! :)
    Yes, a normal FW pin wt will be 20 percent or more. By adding the heavy loads you mentioned, a DRW would be the tool for the job. A SRW may work for you, without the extra tank, but a full load for sure.
    You see a lot of overloaded mismatches on the road, so they are doing it.
    You will enjoy the FW experience. Stay under the RAWR/tire rating, and a FW will handle well, even while a little over payload.
    Jerry
    Dry weight on that trailer is 12600 lbs from the factory. Based on my Grand design trailer add about 400 lbs to that for 13,000 lbs. Add 1500 lbs of stuff you are at 14,500. At 22% pin weight would be 3190 lbs. Add 1000 lbs fuel and 300 lbs hitch total payload is nearly 4500 lbs. My SRW Ram 3500 has a payload of 3830. Seen as high as 4150 when shopping. I think you are gong to need a DRW truck.
  • I guess the question was as much about hitch weight as capacity (since I would be new to 5ver).
    Math follows:
  • This one is pretty obvious with 1000 lb fuel tank, plus heavy hitch. Yup, OP already knows answer to question.
    Jerry
  • Don't even consider an srw with that kind of weight. I towed a 14,000# goose neck shop trailer with one (not my choice), it was not fun or legal.
  • For a trailer that big I would for sure get a DRW truck.
    With a trailer that big you're in the big boy club now. Get a tool which fits the job which IMHO is a LB DRW truck.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
