rvshrinker's avatar
rvshrinker
Explorer III
Oct 12, 2017
New trailer next week, which Andersen WDH?
I am picking up my new 28' travel trailer next week (ORV 23DBS, wet weight 8100 lb). I am towing with a new 2017 RAM 3500 Megacab with air suspension.
The Andersen website says I should measure this that and the other on my trailer before knowing which WDH to order, however I obviously can't do that without the trailer. I really want to have the WDH when I go pick up the trailer to make my first ride home less stressful. It's only about 20 miles but there may be a little traffic.
Based the specs I read him over the phone, the Andersen rep suggested model 3350. And that looks to be their most common model. Can anyone confirm/refute this?
How long does it take to install this? I'm going to be figuring this out in the dealer lot so I hope it's not a nightmare.
  • Yep, if the hitch weight will be more than about 750 lbs (and yours probably will be), the Andersen is reported to have difficulty distributing enough weight to level the rig. It will still provide sway control and some WD.
    Honestly, I would suggest that you make sure your hitch weight is at least 10% of the total TT weight, then drive home without the WD, keeping your speed low (say, up to 50 mph). Setting up a WD hitch is not something I'd want to do in a dealer's yard when I'm tired out from the walk-through and paperwork and everything, and eager to get home with my prize. Wait till a day or so later when you are rested and have a couple hours without stress or reason to rush, and you'll do a better installation.
    For that size TT I'd lean toward an Equal-i-zer, just my personal preference. If you do get the Andersen, plan to drill indents for the set screws because otherwise the brackets will probably slip (been there, done that).
  • I haven't used one but have read about a lot of people having problems with them on larger heavy trailers. The problem seems to be difficulty transferring the heavy tongue weight. They seem to be good for trailers up to 6k but aren't as effective beyond that. Might not be a problem with your truck but you may want to research it more.
  • "I'm going to be figuring this out in the dealer lot so I hope it's not a nightmare."
    The dealer should install your hitch without additional charge. Ask them.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
