Durb
Jul 24, 2017Explorer
A couple of more notes: I use the scales which are about a mile off the freeway on the side of the road on the way to Champooeg State Park (Donald exit). They are free and not busy so you can take your time.
An escalade of that vintage might have automatic leveling which means the rear end will raise when you start the engine. If so, it is important that your weight distribution hitch is set up with the engine running. If not when the vehicle is started the rear end will raise and unload your WDH and place more weight on your rear axle.
If you have any hint of sway I would dump the sway bar and buy a weight distribution hitch with integral sway control. Good recommendations in the previous post.
When he has confidence in your set up and in Astoria, take the Astoria Bridge over to Ilwaco. That thing still tweaks the nerves after all my years of towing. Good luck and have fun.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
