mrekim's avatar
mrekim
New TT, Upgrade the Reese?
I have a new 32’ TT (35’ total) with GVWR of 9858 and a sticker weight of 7,386. The measured tongue weight when TT is level with 49 gal of fresh water in it is approx 910 lbs.
I was able to get the WD system set up so there’s no change in the 2002 PSD Excursion front fender height and a 1” drop in the rear fender height with the existing bars and the TT level (using a level on the frame vs measuring front/rear). I realize this needs to be done again if there’s a bar change and/or after loading stuff up.
I have yet to get to some scales to get the actual weight. It’s on the TODO list.
ok, so on to the question….
My current system is a Reese WD setup with a 1,200 lb shank and 800 lb WD bars. there’s no rating on the head. Given the measured tongue weight, it looks like I need to get new bars and based on additional reading, it seems like it’s strongly recommended to install an anti-sway system as well.
Before investing in new bars and something like a dual cam setup, I wanted to see if I should be considering pitching the head and shank and starting from scratch or should I just upgrade the bars? It seems like bars and dual cam will be about $360-$400 and I’d hate to find out I should have gone with a different solution for $500-600 after upgrading my existing parts. I also don’t know if I have or need “heavy duty” chain lifts which would put me closer to $500 to upgrade.
Also, I read somewhere (but could not find it) that at least one person was of the opinion that the quality of the dual cam system may have gone down to do moving manufacturing offshore. I’m interested in feedback on that “issue” as well.
Finally, is it a common practice to upgrade bars, should I be calling around to local shops to see if I can trade them in for an upgrade?
Thank you in advance for any advice.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 24, 2026
