RoyB
Apr 22, 2016Explorer III
If no has done the cut and paste before your 7-way cable should be a breeze... Most of them terminate into a weather tight electrical junction box just inside your trailer frame... If all is normal all you do is replace color for color. Some are tied together with large yellow twist connectors... Other have lugs and are connected to a terminal strip... Unless someone has made changes already it is as simple of remove a BLUE WIRE for instannce and repacing with the new Blue wire etx...
ETRAILER.com has a nice video showing their 7-way cable being hooked up...
I would replace the whole cable and not cut into it and add a length...
ETRAILER has your exact 7-way cable with molded connector and it used to come in two lengths. Long and bit less than long haha...
Check them out before you decide what to do...
Roy Ken
Roy Ken
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Mar 08, 2025
