YC_1
Apr 22, 2016Nomad
Go to your battery and use the post to test the tester. If it functions ok you need to find a better ground at the hitch. Grind some place shiny clean and connect to that. I actually screwed a crimp connector for a wire on a place made shiny and clean. I can alligator clip to it with confidence. If you have a piece of wire long enough just run it to the negative battery post.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Mar 08, 2025
