JudeG's avatar
JudeG
Newbie Woes re Towing
Please tell me if I've landed at the wrong airport for this question. We have a 2007 Coachmen Mirada towing a manual 2011 Chevy HRR. We've had two occasions where we ended up with undue tire wear on the driver's side, front tire. The first time, about a month ago, we replaced two tires. Discount Tire couldn't figure out what had caused the damage, so they moved back tires to the front and put new tires on the back. Yesterday, it happened again which means we need two more tires BUT I need to know what is causing this problem! We were told the car is to be in neutral, emergency brake not engaged -ha ha- and key turned to first position - ACC. What I'm wondering is if the key is not turned quite all the way to ACC, would that do it? It's the only thing I can think of... The only other thing I can think to tell you is that we have the Fuse #8 bypass switch. Thanks in advance for any input you can provide.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 20, 2025
