Shwthomas1975
Jul 27, 2017Explorer
Thank you. Going to get one. I took the cover off the panel and the little pic fans are spinning, but maybe not charging. I hooked jumper cables from my truck directly to the camper battery. So the battery is dead. Might be so dead it won't charge, but I don't think that's the case. Meter will help tho. When plugged in, how many volts should be going to the battery to charge it?
Makes me think. Isn't the battery after the converter? When it's plugged in, even if the battery is junk, the lights should still work right?
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
