DrewE
Aug 06, 2016Explorer III
Assuming the water heater is drained, leave the plug out and turn on the city water (or water pump). Does water come out the water heater drain hole? If so, that's the summer setting; if not, it's the winter setting, and going to the other position will be summer.
Once you figure it out, maybe drawing a little diagram or otherwise labeling things with a sharpie nearby (assuming it's not in a readily visible spot in your RV) would help you remember for next time.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
