Sudden stop of hot water flow.......check valve in hot outlet (top backside of WH)
has failed.
The check valve is inside the nipple screwed into WH tank.
It is a cheapo plastic piece of junk......plastic plunger/spring/o-ring. O-ring fails, jams up-----no more hot water.
WH tank will have HOT water because none can flow out of it.
So CAUTION of you go flipping T&P Valve open......140*F water/steam will blow out of relief valve.
With water source off, WH turned off and tank cooled down
Remove hot water line and then remove internals of nipple ('C' clip)
Don't need check valve until you winterize (don't need one at all if you install shutoff valve)
