csamayfield55x
Apr 28, 2017Explorer
cm11599ps wrote:
I currently have the batteries disconnected and the camper unplugged from the house. I'd like to see if the batteries can hold the charge cause like I said, I think they're on their way out anyway. I'll play with things again in a few days when I get some time.
Although you may have batteries that are not up to snuff that is NOT your issue! Just like other said, you have something going on in the wiring from the batteries to the trailer. IN my 2005 I had the auto reset circuit breaker fail. It was right below the batteries on the frame. My new trailer has one mounted in the battery box up high.
Follow your hot wire from the frame and find either the fuse or CB and test voltage on both sides of it. There is one somewhere. Also check and make sure your ground wire is attached securely to your frame close to your batteries.
Chris
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
