bunyon14's avatar
bunyon14
Non slip shelf liner
Looking for non slip shelf liner that is about 3/8" thick. All I can find is the thin shelf
Liner. Anyone no were I can find the thicker liner.
  • downtheroad wrote:
    3/8" is almost a half inch thick..seems excessive for a shelf liner.
    Maybe some kind of cushioned rubber mat that you can cut to size.
    Doubt you will find true "shelf liner" that thick.
    Agreed! We use the porous 'rubbery' type from the housewares / kitchen section of walmart. It's cheap and does the trick.
  • 3/8" is almost a half inch thick..seems excessive for a shelf liner.
  • Maybe Look for tool box liners? Though 3/8" is thicker than I've seen.
    The thick stuff is in the area-rug department, as it is used for non-slip liner under small rugs and mats.
    I have also seen it in the bedding area as a liner for under a mattress to prevent sliding.
  • TxCowboy wrote:
    You can find it almost anywhere, including Wal-Mart, most home supply stores, etc. Look for it in the housewares section and in the RV section. It runs about $4 for a 25 foot roll when I purchased my last roll.
    BTW, I assume you're talking about the semi-porous matting that you can trim with a scissors.
    This is what I use, but I have to ask, Why 3/8" ?
  • You can find it almost anywhere, including Wal-Mart, most home supply stores, etc. Look for it in the housewares section and in the RV section. It runs about $4 for a 25 foot roll when I purchased my last roll.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
