edatlanta
May 15, 2013Explorer II
Diplomat Don has the solution. Buy some flat washers and you can add them as needed. Remove the screw on the top hinge and lift the door off of the bottom pin/hinge. Add as many small flat washers as needed to lift the door so the latch clicks. I had to do this 2-3 times early on and finally the door quit sagging as I moved.
I too don't keep much weight in the door while traveling.
A hand full of small flat washers costs pennies.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
