silvercorvette's avatar
May 14, 2013
Norcold refrigerator door lock problem I want a better fix
The top freezer door clicks to show it is locked but the bottom does not click and can be pulled open, which means it something inside the fridge bumps into the door wild moving the contents can fall on the floor. I fooled around with the striker plate and tried to adjust the part that clicks into the striker plate without success.
(I think that striker is the correct term for the gray colored piece that fits into the hole of the striker.)
Then I got the idea to pull up on the bottom of the door. Lifting the door up moves the striker enough for the striker to lock into the hole in the striker plate. Pushing up to raise the door and easy but temporary fix, I want to better permeant one. I noticed that there is a screw on the top hinge. i am guessing that turning the screw will raise or lower the door height but haven't had a chance to try it because I planned on being 1/2 way to NY by today, and I will not have the time to adjust the door till I make my first overnight stop at a camp ground. If my theory about turning the screw to adjust the door is wrong then how do I raise the door.
  • Sounds like u have the right idea on adjusting the striker...if it were me I would see if I could adjust it so it will lock....just my 2 cents worth..
  • We just use the plastic spring loaded fridge bars to hold the fridge contents in place during transit.
