TubaPete wrote:
Sounds like your tow vehicle has seperate lights for turn and brake (amber and red, maybe). A 4 pin combines turn and brake into one light on each side. You need to install a wiring adapterin your vehicle to combine the two lights on eahc side into one. You can get it at almost any big box store, e.g. Walmart, that carries automotive supplies.
MH brake and signal lights are separate. I have an led tester just like that and it reports things work as they should (although the back up light flashes slowly)
I have a 4 to 7 adapter like this http://www.amazon.com/Reese-Towpower-74607-Wiring-Adapter/dp/B000CPI6VI/ref=pd_sim_sbs_auto_3 and a 4 pin tester like this http://shop.trailerlightcheck.com/Vehicle-Wiring-Tester-LCV101.htm connected to it just to rule out the marker wiring.
