I've just changed my oil in my Georgetown 350 SE, and wanted to offer a few tips. First, the oil plug and filter are easy to get to and obvious, but you will need a few things to avoid a mess. The p...
I am lazy... I use an oil evacuation pump so I don't have to get underneath with a pan. If the evac tube hits the pan, I can even get the sludge that builds there that doesn't run out normally. Some new import cars don't even have a drain valve anymore, so changing the oil requires either an evac pump or dropping the entire oil pan.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
