buc1980
Mar 27, 2019Explorer
Oil change
How many mile you drive pulling the FW before you change the synthetic engine oil?
Eric&Lisa wrote:If what you're saying were true, then you may have a point, but there's just too many points that are in error to bother trying to rebut.fj12ryder wrote:Tom N wrote:The cheapest one obviously. If they're using good oil then the engines are basically the same. No biggie.
I like to equate oil change intervals to buying a used vehicle.
If you were offered two exactly the same used vehicles, one that had the oil changed at 5,000 miles and one that had the oil changed at 10,000 miles, which one would you chose?? And why??
I disagree, but maybe I am reading more into it than just an oil change. One vehicle was maintained with "What service should I be providing?" The other vehicle was maintained with "What is the minimum service I can get by with?" I think the oil change frequency is an overall indicator of the level of care provided for a used vehicle.
Maybe you are right about the oil, and the debate will continue on. However I will maintain that someone who is actively seeking reasoning & justification for the minimum level of oil changes will also defer other vehicle maintenance.
Let me pose a different line of thinking....
A quick Google search says a 2019 Chevy 1-ton dually gasser is around $50k. Another quick Google search shows oil changes cost $25 on the low end to $70 on the high end for synthetic. 100k miles at 10k oil changes is 10 total changes - or $250-700 total. At 5k oil changes that doubles to $500-1400. Seems like pretty cheap maintenance on a $50k investment, especially if this is spread over a the number of year it will take to accumulate that 100k miles.
A $50k truck for 100k miles is going to cost $.50 per mile just for the vehicle purchase price. That truck gets 12-17 miles per gallon, and will burn through around 6000 gallons of gas to go 100k miles. Picking $3/gallon, that is around $18k in gas, or $.18 per mile. That puts the truck at $.68 per mile for ownership + gas on the first 100k miles. Keeping this simple and erring on the side of conservative math, I will leave out the dollars spent on taxes, registration, insurance, and other typical cost of ownership expenses.
Let's say $1000 is spent (middle of the estimate range) on oil changes every 5k miles. That is $.01 per mile for that 100k miles. The cost of vehicle + gas + oil has now increased from $.68 to $.69 per mile. If I push to 10k oil changes, that only drops 1/2 cent per mile.
So I have to ask... With this kind of money on the table, is saving 1/2 penny per mile really that big of a deal? If budgets are so tight that this is really that important financially, then I would question the wisdom of purchasing of a $50k truck in the first place.
Several people have mentioned Blackstone Labs testing. Their price for a standard analysis is $28. Let me see if I get this straight... Take time & effort to gather an oil sample at 5k miles. Send it off. Wait for a response. Put off an oil change until 10k miles. The purpose of testing is to see the changes from a baseline test, so re-test to see how much the oil degraded in the second 5k miles. Justify the decision to put off an oil change, although $56 + time & effort has already been invested. Play the one upmanship game on Internet forums bragging about how far they go between oil changes. By the time this horsing around is done, the oil could have been changed at the recommended interval for about the same amount of money & effort.
That's my $.02 (or the cost of an oil change for two miles of driving)!
-Eric
