dcmac214 wrote:
Is there an online cross-reference that will identify different brands oil filters by size and thread? What I want to do is find a longer (= more filtration surface area) filter for the Camry, hopefully without plowing thru 100s of filter specs one by one. Camry would take a 12" long filter if someone made one that long.
Why? I have a Mazda that has over 300,000 on it. Does not use oil and runs like a top. No fancy synthetic oils or fancy filters. I bet the filter is somewhere around 3" long. :E
Unless you're doing extended drains there should not be that much contamination in the oil to clog up a factory filter.
