luberhill's avatar
luberhill
Ok OCD kicking in... shower surround cracked
Ok I noticed these cheapo plastic shower surround on my Winnebago Vista 26he has a crack in the lower surround, I doubt it would leak as it’s on the wall under the shower head I ran a bead of caulk over it.. not sure what’s even under the shower...
Looks like the water connection for public water...
Should I replace it ???
Wonder how much it would cst... the shower pan itself is perfect
  • Did you drill a small hole at the end of the crack to stop it from running?
  • wonder how hard to get that surround off ??Id take it to my shop and fiberglass cloth the back side....do you think Winnebage still carries these replacements ? Its a 2013
  • It cracked because they overtightened the screws in plastic... again the pan is very solid and much thivker
  • There is a reason that it cracked. I would pull it down, correct the sloppy workmanship, check the pan for proper support and correct any sloppy plumbing work. Look at as an opportunity to gain a better shower.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
