rexlion
Jun 20, 2020Explorer
DrewE wrote:I've never heard this. I had been looking at the Baofeng UV-5R. You mean, even though it can access GMRS frequencies, I wouldn't get into trouble doing so because it's classed as "FRS only"? Or have I misunderstood?rk911 wrote:
please note that an FCC-issued license is required to use frequencies assigned to the GMRS. you may inadvertently be usung a GMRS repeater. given the size of the radios and the max power output of 2-watts it is unlikely (but possible) to achieve the advertised 28-mi range. use of a GMRS repeater makes that useful range much more likely. but of course you would need a valid GMRS license in order to use a GMRS repeater. if you have such a license you're good to go.
It's also worth noting that in 2017 most of what had been GMRS-only frequencies were redefined as being FRS frequencies, and nearly all of what were previously handheld FRS/GMRS combo radios "magically" became FRS only radios and do not require a license to operate (i.e. they're licensed by rule).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
