Slowmover
Jul 05, 2020Explorer
Twice in the past three weeks have been able to divert around a closed Interstate due to fatality and NOT get trapped on an alternate routes with the illiterates.
A better than average CB radio system, an Atlas, and knowing how to use both takes practice.
(The usefulness of Waze is in knowing how the stupids will respond. Mob prediction).
Your commuter miles in a metro area don’t count when out on The Big Road.
Take that as a humility pill, if it’s understanding you want. The assumptions about services will put you into real trouble if you miss the mark.
Today’s cars are harder in which to make a good radio installation than a 1971 Dodge Polara wagon, and while experience in mobile radio use adds confidence, it still needs to be turned on more than turned off.
What distinguishes the road of today versus 1980 and earlier is that the level of co-operation has dropped to near zero. CB Radio replaced a whole slew of hand and vehicle signals needed to negotiate two-lane highways.
Bad driving practice is universal now. Include yourself. Metro commuter habits are worse than terrible. It’s ME versus being WE. Rules are for someone else. The underlying principles don’t pertain to special people.
Most truckers don’t use CB, install, or know how to do either. Most private vehicle owners aren’t willing to do a good installation of a radio and antenna system, much less invest the time to learn its ways. Again, include yourself. Humility is: don’t yet know what’s possible.
It’s the Citizen Band. Not the Slave-Tracker (cell phone).
You’ll get what you put into it. Use the Internet window while you can.
There are experienced operators out there DESPITE morons crowding some areas at some times. Better radios can scan all channels fast. AM-19 isn’t the only action
An NMO-Mount Larsen NMO27C on the roof practically guarantees king of the hill status in terms of being heard — and being able to hear — with a radio system of reasonable cost (well-installed).
Your neighbor with an antenna stuck to the aftermarket rack on his pickup for his CB hasn’t a clue. That’s performance as bad as most composite-body Class 8 trucks of today. Abysmal.
1). Radio gear will last a decade or more in constant use. The price divided by ten years is next to nothing when compared to cell phones, WiFi routers and the rest over the same period.
2). Where family vehicles — all of them — also feature radio installations and there’s a radio at home mounted under a kitchen cabinet completes a circle not dependent on your owners willingness to allow you communication AT A DISTANCE.
3). Other radio modes may be “better” in a technical comparison, but CB is the one that’s everywhere in someone’s attic or garage, gathering dust. What you and your family have is one thing. What MATTERS is what you share with your neighbors.
— a record number in Great Britain are sitting for Amateur Licensure. Reports here are similar in re equipment purchases and interest.
4). The “minimum” unit is AM/SSB capable. Sideband is the bees knees. Solid-value & rock-steady performance is with the Uniden 980 at very low cost. ($180 retail, $140 all over). I recently sat in NE Ohio on a break and listened to Wisconsin talking with Georgia. Florida, with Chicago. 11-Meter is an introduction to Ham Radio (Amateur), but without having to prove technical competence through licensure.
— while conditions and gear questions apply, conversing with others in the Caribbean, South America and Europe isn’t outside what’s possible. Canada and Mexico aren’t anything remarkable. No, this isn’t automatic or plug & play. . But it’s close.
5). An RV is a natural home for Radio. Wherever it is. Mobile, or stationary. Any tools or supply needed to make installations is reduced when spread across home, family cars, and an RV. Money spent is in paying yourself is an important understanding.
— the 1960s saw the peak of RV adventure travel. It established a norm of having a “campground radio” as common right into the early 1980s. CB outnumbered TV in use by a large factor. One IS dependent on others, thus easy communication “fixes” problems, one man to another, one family to another. Ordinary AM radio had at that point a thirty year history of providing local news and maybe weather. Network-affiliation. Shortwave, the international scope. CB was what closed the loop. The “adventure” was in providing ones self with what before was corporate-controlled.
— A cell phone connects you to someone with their hand out for money. And then only if they deem you worthy of access. Not yet banned. The Net is no different. Full dependence is the model. AWAY from independence.
6). RADIO is a system of systems. Of which — by far — the most important is the antenna system. That all parts of it work together. There are simple and complex mobile antennas. An RV Radio is likeliest to be used while stationary, so one is not limited to typical mobile mounting. (Motorhomes have their own problems, but nothing that applying one’s self can’t remedy). A tripod-mount away from the vehicle or a wire antenna strung in trees are starts. CB is generally, but not wholly a line-of-sight TX/RX performer. As to antennas: Height is Might.
7). An installation where details are attended to the higher standards of Amateur Radio ensures best performance. And eases entry to that world should it prove attractive. Makes every vehicle or structure treated that much more valuable. The cost of quality supply goods is as nothing compared to the brains to use them well.
8). Many will worry over memory or reports of CB Radio theft sensationalized in the 1970s. The Enemy wants you dependent, should be your first reaction. And common sense should dictate how to look at the problem otherwise.
— What’s in your RV or home is easily concealed from view.
— Your family vehicles need this: Don’t tell a story to a passer-by. Mounting a radio inside a console or on the back of it is one approach. An NMO-Mount antenna can be removed and the mount capped (no, a magnet mount antenna attracts MORE attention, and suffers significantly diminished performance). If you want the most, get the most. And that’s in the installation far, far ahead of the gear chosen.
9). As to a large difference between CB and true Amateur Radio equipment Digital Signal Filtration in the audio chain so lessens the noise that signals previously unknown can now be not only deciphered, but one can at times communicate. Ears trump Voice.
— there is quite a bit of Amateur equipment being used on 11-Meter (total number, not percentage) even though it is prohibited. “Noise Abatement” is a large reason why.
— there are stand-alone DSP units that go between radio and external speaker. I prefer where it’s integrated with a mobile speaker, specifically, the West Mountain Radio ClearSpeaker. A $200 purchase I made six years ago and has covered past 300k miles in a big truck including off road oilfield without incident. Marketed to the Amateur crowd, it’s an amazingly effective device. There are those with $2,000 HAM radios who use it even though the radio has a multitude of filtering controls built-in.
— a guy with a good radio system — “better” than mine — will tell you he gets reports of problems 7-8/miles away. That’s outstanding . . . but I get them 12-15/miles out with the WM Spkr added to a VG installation.
10). CB Radio was given a clowns image by Hollywood. (Gee, imagine that). It has no substitute as the immediate area communication device. As before, your family or group may use another choice. So what? Eventually it WILL matter you can speak with strangers nearby. Who, remember (even if you haven’t the experience) have the same concerns and feelings as you.
11). The basic system, IMO, is:
Uniden 980 AM/SSB Radio.
RM Italy KL203 amp
SOTABEAM 4-way DC distribution (or similar; make disconnect E-Z).
Harbor Freight “Apache” 3800 Transport Case to keep it safe.
This set-up outperforms every high dollar Big Radio.
Use as is. No upgrades or grubby tech fingers inside units.
(The amplifier is small and the current draw remains under 20A for all devices working at peak. Get at 88 Radio website. Yeah, CB is limited to 4-watts. But this isn’t nice & quiet 1959 any more.)
This radio rig is, Hear & Get Heard.
The default mobile antenna is ALWAYS the quarter-wave whip. 102” Stainless. All else tries to emulate its virtues. Skipshooter is an excellent American-made top-load whip. Limit overhead clearance to 13’5” maximum. Aim at height as the virtue.
More money pertains to supply & tools depending on what you already have. The above is the best $500 you can spend. Over ten years it’s $4 per month. Mine pays for itself all over every couple of months.
Safety on the road is risk-avoidance. Knowing what’s around a curve ahead doesn’t have a price tag. One serious accident is life-changing. (Waze and the like are too slow EVEN IF they report).
Extrapolate the desire to make choices to more than just what’s on the road. Rioters in Nashville mean I’m not using IH-40 to travel west and am now diverting north to IH64 across Kentucky. No propane in one place. Power out in another. Etc
And, for what it’s worth, some of the funniest things I’ve heard in this lifetime came across that radio. It’s friend, fair weather and foul. A good place to eat. A fair-minded tire store owner. Heavy crosswinds just ahead.
A). The bible of Amateur Radio installation is at (link)
K0BG
He includes many links. Make notes.
B). Internet retailers of repute (all of which I use) include:
Bob's CB (Pennsylvania)
Bells CB (Florida)
Walcott CB (Iowa)
DX-Engineering (Ohio)
Universal Radio (Ohio)
HRO Ham Radio Outlet
(Online, and regular retail across nation)
Radio Shack is long gone.
Websites include:
RadioReference
WWDX
QRZ
Equipment Reviews at
CB RADIO MAGAZINE
eHam
YouTube
Farpoint Farms Series (on the 980 as SSB choice).
“102 Whip CB Base Station Antenna” (title)
As before, one gets what he puts into it. Read up on best practice.
RM Italy KL203 amp
K0BG
Bells CB (Florida)
Walcott CB (Iowa)
Websites include:
RadioReference
WWDX
QRZ
CB RADIO MAGAZINE
eHam
YouTube
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
