- wanderingbobExplorer IIKinda common , it is called a medium base Edison 12 volt bulb .
- CavemanCharlieExplorer IIIHuh, All the 12 volt bulbs I've ever come across were a different base. Learn something new everyday I guess.
- wa8yxmExplorer III
twodownzero wrote:
I don't think a light bulb cares what kind of current is flowing through it. It's a purely resistive load.
True for the old incandescent types but it does care about voltage. The standard house lamp is 120 volts. The DC lamps are 12 volt so you plug a 120 volt lamp into 12 it will be very very very very dim.
Most every hardware and automotive store sells standard edison base (Screw in) bulbs that look for all the world like a 100 watt 120 volt bulb till you read the label. 12 volts. they are usually rough service designed for drop lights (trouble lights) I have one around here somewhere. - JRscoobyExplorer III have had a bulb like that for years. Replaced the plug off a drop light cord with a pair of clips.
Not as handy as I thought it would be, but better than most lights that where available at the time - Beverley_KenExplorer
ajriding wrote:
ok, Ill toss in trash then.
I thought it would blow if put in a 120
If it is a 12 volt bulb, regular screw in base and you put it in a 120 volt lamp, it will work for about a milli-second, then you will throw it in the trash.
Ken - Boon_DockerExplorer III
Yes, it would be ruined if you applied 120 v to it. - ajridingExplorer IIok, Ill toss in trash then.
I thought it would blow if put in a 120 - cavieExplorer12 volt blubs are common place.
- boogie_4wheelExplorerIncandescent bulbs operate on AC or DC, just as long as they are the correct voltage.
In a lot of the substations I work in, there is an emergency lighting circuit that has a bunch of 100W bulbs connected to the 125V battery back (~130V float). In the event of a station outage (loss of station service) we can turn on the emergency lighting powered directly by the battery bank.
Nothing special about the bulbs, just your typical 100W 120V. - twodownzeroExplorerI don't think a light bulb cares what kind of current is flowing through it. It's a purely resistive load.
