JRscooby
Apr 18, 2020Explorer II
SweetLou wrote:
I have an old '66 fiberglass enclosed trailer. It has round taillights which insert like a cupholder with metal component and a snap ring. When going down bumpy road the ground gives out and being fiberglass isn't always easy to get a good ground. Does anyone know of a replacement either original or something newer?
If the issue is ground, replacing the lamps will not fix it. Some say run a ground wire to frame. For decades I have ran the ground just like power, all the way to plug. Most of the trailers I pulled with CMV, the frame was above ground. No benefit to grounded frame. And above, power makes contact with frame, the lights keep working.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
