Golden_HVAC
Jun 15, 2014Explorer
Hi,
It is my guess that fuel problems are the problem. Your generator might have a gummed up carburetor, and that is the cause. Run it some more, and put a 1000 watt load on it as much as you can. Monitor the voltage. While the coffee maker and electric heater can run fine with 100 volts, the A/C can not.
Run a electric heater that has a high and low heat setting, and switch to low heat when the engine bogs down, then back to high when you can. Running a couple of gallons of fuel through the generator should clear up this situation.
You might also need new fuel in the RV if you have not taken it on any long trips. My suggestion is to try getting it as close to empty as practical (don't start out across the desert with only 1/8 thank though) and plan on finding fuel along the way to wherever you are going, getting to the last practical fuel stop along the way, then buy about 10 - 15 gallons, and that will give you a mixture of only 10% old stuff to 90% new stuff. Using up as much of that mixed old fuel as possible, then filling completely with new fuel should give you a "New" tank of fuel, that will not be causing problems that can be blamed on old fuel.
Also remember that your generator takes fuel from only the top 3/4 of the tank of fuel, so will run out before the gauge reads in the 1/4 to 1/8 full range. So you will have to fill to at least 1/2 tank if you plan on dry camping.
If you can get to the carburetor, and know how to remove the air filter, you can try running it and spray in some carb cleaner. You will need to keep a load on the generator, such as a 750 watt electric heater, to keep the engine running more than 20% open throttle. Spray it in slowly, in short bursts, because it is designed and the nozzle sixed for a much larger engine in the 50+ HP range, not the 8 HP engine on your generator. At only a 750 watt load, the generator will only need to make about 4 HP to keep running.
Also check your air altitude valve. It should be set to near your current altitude, mine has something like a 1,000, 3,000 and 6,000 foot setting. I set it for about 3,000 and leave it there, due to air restrictions in the air filter making it "Feel" like the generator is running a slightly higher elevation that it normally is.
Hopefully it will start working after running it a couple of hours at as close to full load as you can get it with a electric heater, tea kettle, ect. You can also cycle all those off at the same time as starting the A/C and see if that works. The engine will already be at 50% throttle with the tea kettle and 1500W heater, then drop off at the same time as you start the A/C, it should work.
Fred.
Fred.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
