Ro646a's avatar
Ro646a
Explorer II
May 15, 2018
One oil change in 11000 miles?
I'm considering a beautiful, garage kept 2007 Winnie Adventurer with the W24 Workhorse chassis. Unfortunately, it has only had one oil change, and that was at 6000 miles.
I also wonder about the engine coolant and the potential for corrosion.
Should I pass?
  • Bobbo's avatar
    Bobbo
    Explorer III
    My new 2017 F-150 recommends oil changes every 10,000 miles or 1 year. The first oil change at 6,000 miles with a second at 11,000 miles wouldn't worry me at all.
  • You could go the lab route, but how does the oil look? Milky at all? First concern would be if there had been any moisture buildup due to long term storage. Did they excercise the engine at all? What types of trips did they make? If they took the unit 20 miles to a local lake a dozen or more times a year, I would think it was fine, all the fluids were warmed up and circulated frequently. Or was it one or two 3000 mile trips in all those years, meaning those fluids sat dormant for long spells.
    And that same concern would go for the tranny too.
  • Anonymous's avatar
    Anonymous
    If it already had an oil change at 6K miles and the moho now has 11K miles, it tells me it's due for another change right now. I won't be too concerned.
  • With today's kinds of HI-Tec oils I wouldn't think it would be a problem. Do you know the kind of oil the owner was using?
  • Take an oil sample and have it completely analyzed. They should be able to give you a handle on how much acid and other contaminates are present. Be sure to tell them the situation you are in and ask for their recommendations based on what they find. Blackstone Lab or JG Lubricant Services are a couple of good ones.
  • 6000 miles is not that bad , your heading says 11000, that is 2 many
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
