BarneyS
Oct 14, 2019Nomad
Try jacking the trailer up higher while hooked to the truck before you start to draw up the chains. It won't hurt the truck or trailer at all. You should raise it high enough so that you can easily put the chains on the hook and draw them up. It will seem very odd at first and you will think you are going to break something , but it is fine and is the proper way to do it. If you have an electric tongue jack then the job is almost effortless. The higher you jack, the easier it will be.
If not, then look at it as an opportunity to get a little exercise in before you travel.
Do the same for unlooking also - much safer that way.
You always want the same number of links under tension on each side.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
