83trekker's avatar
83trekker
only 1 of my 4 tires is worn off on the inside
i have my 99 27ft 5th wheel , went to go start repacking wheel bearings and noticed the right rear tire on the inside is totally worn off. Not sure when this started. Could a loose wheel bearing cause this? Seem a little loose when i was checking it.
  • time2roll wrote:
    Take a close look at the tire to make sure it is very round and flat across the tread. MAXXIS are good but not perfect. I have had tread separation.
    Also check the springs have a nice arch to them. Mine were flat and sagging bad enough at one point to throw the alignment off.
    Thanks will do, i have my 5th wheel at a storage place so next time i go out will look over everything like that too.
  • Take a close look at the tire to make sure it is very round and flat across the tread. MAXXIS are good but not perfect. I have had tread separation.
    If you find absolutely nothing you can swap the tire to another position or get a new tire. If it repeats you are probably looking at a new axle.
  • When i get back out to my trailer i will look over the axle and shackles, thanks
  • I had the same problem once with only one tire wearing.
    This is what I found causing the excessive wear.
    Several years ago while going from Flagstaff to Albuquerque I had an axle collapse. It was replaced by Lippert but it was due to some very bad chuck holes that I could not miss due to the size of the chuck holes a very heavy truck traffic.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
