Grit_dog's avatar
Grit_dog
Navigator III
Oct 03, 2018
Over or Under?
Given some of the recent "discussions", I feel slighted that I haven't had a question or an issue up for debate....errr I mean comment in a long time here.
So, if we can get to double digit responses on things like front end alignments and tire plugs and let's not forget the ever popular 2500 vs 3500 and GVW vs GVWR (and all of it's associated discussions), I want to pose a question to the crater of wisdom here.
Over or under? We all know that over is the best way to install a roll of TeePee in the bathroom in your home.
But what about in an RV, and what if it's a wet or dry bath? Does the orientation matter if it's special RV TeePee or just regular ole store bought?
Is it the same recommendation for single ply vs quilted 2 ply?
What if it's scented?
If my Tee Pee holder is on te outside wall of the RV will installin it one way or another affect the sway of the trailer or camper while towed? Same if it's on a back or front wall? Do you remove the roll less it's a certain % used before towing due to tongue weight limitations or CCC concerns?
This has been heavy on my mind recently, as I've spent the last few weeks living in my camper. Noticed the TeePee roll was installed "under" and I wonder if that added to the body roll in the corners when I drove it over here? Gotta be something, caused it, so figure I'd start with the easy things and move up from there.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
