Searching_Ut
May 18, 2013Explorer
As I recall, in many, if not all areas of the US the "trickle" is a code requirement which came about around the same time that the pressure balancing shower heads became required. It's to help keep the temperature consistent. If the item is designed to work in a building, it will almost certainly not shut all the way off.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
