BarneyS
May 10, 2013Nomad
My opinion is that as long as the tires are well within the weight rating of your truck when loaded, and as long as the rig handles well on the road, then I would keep them until ready to be replaced. I would keep them aired up to near or at the max sidewall pressure for stiffness when towing and keep an eye on the tread to make sure you are not over pressuring them and causing undo wear.
I do not think you would be unsafe using the stock tires as long as handling is good.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 27, 2026
