free_radical
May 23, 2017Explorer
Queens Carriage wrote:
I know this has been talked about 100000 times. But one last time.Going to scrub roof the best I can then put eternabond tape on all seams then paint the roof ( Tired of the white chalking running down the sides. So Wash, Wipe with assitone, apply tape, then paint roof. Now the big question?? What would you to paint the foof? I was told by one person He used Blackjack 1000, from Lowe's. What would you use? or what did you use? Want to get it right the first time' Just tired of the wite chalking down the sides of the RV.
I used to paint my roof with marine enamel,,lasted about 3 years,
then needed repainting,,,mind you roof is made of plywood coated with Cold cure epoxy..
Got tired of painting,got 0.020 aluminum sheets and glued those on using
very expensive epoxy adhesive..
Should last longer then any other coating or even EPDM..
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
