wbwood's avatar
wbwood
Panel access ideas
To get to my water pump to winterize and dewinterize, I have to access the water pump behind a wooden panel. To remove the panel, I have to take out 2 screws. After doing this over the last few years, it's starting to mess up the wood behind it and not really having much to bite anymore. Anyone have an ideas of any tpe of fasteners that I could use to keep that panel on there and make it easy to access without tearing up the frame behind it?
Thanks in advance.
  • Magnetic cabinet latches. Just pull the panel off as needed and snap it back in place when done.
  • You could use a threaded insert installed the the wood and use a standard or wing-type bolt. Or a stud installed in the insert and a wing nut.
  • Put 2 hinges on the panel and a pull knob. Then it will open like a cabinet door. I did this for access where my power cord shoves through the wall from the outside so I could put a portable surge protector. Easy access now. Just pull the handle. Done!
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
