thirtydaZe wrote:
I dont really need to actually, i was mostly concerned in not doing so that i might be creating an issue inside the tank.
If its safe, im going to leave it alone.
Depending on the condition of the tank(s) it should be fine to leave some water in the tank(s).
My tanks are often 1/2 full or more (i have 2 tanks 110g each).
Its probably not a bad idea to rinse the sediment out every few years (but its not imperative).
Depending on where you live & how you store the coach you might need to drain the tanks (and blow out the water lines) in the winter.
I DO drain my hot water heater (if the coach is gonna sit for more than a couple of weeks) - its easy for me to drain my hot water heater, & it prevents sediment build up & prolongs the sacrificial anode rode from deteriorating so quickly.
