theoldwizard1
Oct 30, 2013Explorer II
Pathfinder75 wrote:
etrailer.com is a good source for trailer tow information including wiring. SEE: http://www.etrailer.com/faq-wiring.aspx This shows the popular 7-pin flat terminal and other plug setups with proper positions for circuits.
etrailer.com's diagram for the 7 blade Pollack connector matches the Ford diagram.
I might make a jumper to replace the "auxiliary power" relay so I have the option of it being "key on power" or "hot at all times".
The relays and fuses are all installed, so I wonder if there is a pigtail coming out of the fuse box (under the hood) and where does it end (it obviously NOT go all the way to the back) ?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
