Whiskey_River's avatar
Mar 13, 2020
Pin Weight
Reading thru the minihub67 post, using Jimnlin & other posts do I have this "pin weight" thing figured out??
I have 2008 Ram 2500, 6.7 diesel.
Tires are Michelin E rated 265-70-17 & say 3195#. X-2 is 6390#
The door sticker says Rear 6010#.
Cat scale says Steer Axle 4560# & Drive Axle 2960#.
Door sticker of rear 6010# less scaled drive axle 2960# = 3050#
So my max pin wt should be aprox. 3000#, is this correct?
The 2960# scaled drive axle weight is full of fuel, Reese hitch, Honda gen. & misc. Ready to hook up and go.
    You'll be way over on the trucks GVWR with that pin weight. I would say you GVWR is around 8,800 lb being a 3/4 ton.
  • Cummins12V98 wrote:
    Old-Biscuit wrote:
    YEP.............simple math
    RAWR 6010#
    Drive Axle Scaled 2069# (camp ready weight)
    Available weight 3050# (amount of weight that can be added to rear axle/carried by rear axle)
    Tires 3195/2x 6390# (tires good with 80psi air pressure)
    Rear Axle weight limiting factor.
    2008 2500------------12K 5th wheel
    HOT DAMZZZ, we agree! :B
    every once in a while you come around to thinking clearly....:B :B
    RAWR 6010#
  • YEP.............simple math
    RAWR 6010#
  • That tells me you can tow a fully loaded 12k 5er at 25% pin, maybe a bit heavier but most people have no idea what their pin really is!
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 25, 2026
