Lynnmor
Sep 22, 2013Explorer II
run100 wrote:
Just had to deal with some serious sap on fiberglass and also the ladder. I started with the ladder and tried everything imaginable with no luck. I'm thinking with temps around 110-degrees, it becomes a permanently glazed surface.
Then, several people suggested acetone. Man, that stuff worked amazingly well! I barely even touched the sap on the ladder and it came right off. I also used it on the fiberglass and had the same results, with no damage (afterwards, I washed the areas thoroughly with soapy water).
Acetone will melt some plastics instantly, be careful with using that chemical.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
