DownTheAvenue
Apr 09, 2015Explorer
rvit wrote:
This may help some folks make up their mind. We purchased our first MH 1 year ago and have made just about all the mistakes a newbie can make. But one thing we got right was deciding to use air to winterize instead of the pink stuff.
Ah, but your inexperience is showing again. Blowing out the water lines can be effective, and certainly was in your case. But you are failing to realize that even a minute amount of water left in the lines and collects in a low point, especially an elbow, can cause a very expensive repair. You are also failing to understand that pressurizing the fresh water inlet does not do anything for any water left in the pump or the water line from the fresh water tank to the pump.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
