mobeewan's avatar
mobeewan
Pinkish-orange algae in water lines
I have the translucent pex tubing that you can see through that is like the plastic in milk jugs. There is as light pinkish orange discoloration on the inside of the tubing. I believe it to be the same algae stains that are around the edge of the tub. I plan on doing a good cleaning of the trailer soon and will be winterizing. I was thinking of using the winterizing connection and adding either dilluted peroxide or straight white vinegar into the lines and soaking for a couple days before flushing and sanitizing and then winterizing the water ststem. I would like to dissolve any organics in the tubing to get rid of them. I know bleach will sterilize everything but i also want to remove any deposits left in the tubing. Any recommendations from anyone that has done anything similar? I'll be doing the cleaning the FW tank too.
  • All I can say is, try it! See what happens, and give us a report back, because it's quite obvious up to post #6, no one has done this. Maybe post #7 has?
  • Please reread my op. I never said it was calcium. It is organic probably algae. I don't want to just change the color. I know about using bleach and have used it many times in the past to sanitize the FW tank and lines. I'm looking for suggestions from those with similar past experience and if they used peroxide or vinegar or something else besides bleach. Ultimately I will be using bleach in the final step to sanitize once again but I'd like to make sure I get rid of any residue or deposited since I can't scrub out the lines like i did my FW hoses.
  • I've never seen calcium with color. Have you tried bleach yet? I've seen that before in the shower and bleach kills it off
  • It's not antifreeze. I haven't use it in years. The discoloration occurred long after the last time I used it. I have also had the algae in my white city water hoses. Before bleaching them I have run a string through them with a wad of cloth attached at the end to wipe the inside of the hose. Like running a cleaning patch through a rifle barrel. Can't do that with the plumbing. That's why I was thinking about the peroxide or vinegar. They shouldn't hurt the plastic tubing and fittings. Vinegar will dissolve calcium deposits in coffee pots and is recommended by Atwood to kill the sulfer odor that can occur in their water heaters. So I am leaning towards using it.
  • DrewE's avatar
    DrewE
    Explorer III
    Are you sure it's not staining from RV antifreeze dye or possibly some mineral deposits?
    I don't think you'll find anything that will dissolve algae or bacteria cells but not be harmful to plumbing or human cells. Some sort of mechanical cleaning (i.e. scrubbing or flushing with a lot of water) would probably be the most effective if it is indeed some biological contaminant.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
