luberhill's avatar
luberhill
Pls explain 30amp vs 50amp wiring and breaker
Ok so is this correct;
say my RV has a 30amp service and I want to wire an outlet in my pole barn. I just use a STANDARD 30amp single pole 110 breaker and run 10 gage romex to the outlet ?
Now lets say I have a 50amp service, I assume I can run that on the 30 amp service but only one side of the line on the RV will be hot ?
Now lets say I want to run a 50amp outlet ....I assume I have to use a 220 50 amp double pole breaker so that it feeds power to both sides ?
And would I need 8gage wire ?
  • I think you have it figured out correctly. There are several posts about that wiring with good diagrams attached. Try searching it out.
Looking for advice before your next adventure? Look no further.25,166 PostsLatest Activity: Sep 26, 2025
